| Check battery voltage, on mine key switch was bad, let starter run when engine was running and dropped battery voltage below 12 volts. I wiggle key switch, starter stopped running, battery voltage came up again after a little bit, backhoe could move again. Could be alternator or problem like mine.
Check for relays, if they would come loose, fall out went ramming around pushing with loader. Fuse panel in front of steering wheel on top of dash. Remove two screws pull off panel.
