Farmall H M&W 9-speed
International Farm
Posted 12/22/2015 07:37 (#4978328)
Subject: Farmall H M&W 9-speed
Northeast Nebraska
I have a farmall h with an m & w 9-speed transmission in it. A tooth broke on one of gears, got caught and locked it up. We have it all a part and I am wondering where I might find parts. Two gears have one tooth missing, if I can't find parts do I dare put it back together with the old gears. Thanks in advance.
HOGFARMER
Posted 12/22/2015 07:40 (#4978335 - in reply to #4978328)
Subject: RE: Farmall H M&W 9-speed
NE OHIO
I would take the gears to a machine shop to see if they can duplicate them or put a tooth in as a last resort.
Josh in Pa
Posted 12/22/2015 07:46 (#4978347 - in reply to #4978335)
s.e. Pa
In the local farm paper there is a machine shop that advertises they can make gears, either one or a production run. I'd look around for something like that. You could also ask on ytmag.com in the farmall section. Maybe someone has one for parts?
Josh
E718
Posted 12/22/2015 07:50 (#4978356 - in reply to #4978328)
Sac & Story county IA
You should look around at the collectors sites. Try to find the gear out of a salvage unit. There are places around here that make gears but it will cost $300 on up. One quote was $1300. Look for awhile first.
pirlbeck
Posted 12/22/2015 08:01 (#4978387 - in reply to #4978328)
West Central Iowa
Do the gears you need have any part numbers on them or can you find a parts listing that would give you the part numbers? If you have the part numbers, a Goggle search MAY turn up something.
tj_farmer
Posted 12/22/2015 08:25 (#4978431 - in reply to #4978328)
NW central IL
not sure if m and h 9speeds are different but if you can post a pic of gears need. I bought a crate of old 9speed parts at a auction. im not sure all are m parts even. if you post a pic ill look through my pile to see if I can help ya out...
shoop
Posted 12/22/2015 08:39 (#4978457 - in reply to #4978328)
M
Try Lieske tractor at Henderson mm. 612-203-9256
shoop
Posted 12/22/2015 08:40 (#4978458 - in reply to #4978328)
M
JohnW
Posted 12/22/2015 12:15 (#4978901 - in reply to #4978328)
NW Washington
Try Bates Corp. They have a lot of used Farmall parts and may have a M&W gear set. http://batescorp.com/
seagram
Posted 12/22/2015 15:31 (#4979220 - in reply to #4978901)
ne iowa
m and w and heisler 9 speeds are different.
4th GenerationFarmer
Posted 12/22/2015 18:34 (#4979597 - in reply to #4979220)
Subject: Different makes of 9 speeds
NWC Ohio
I'm not sure but I do know of two different Farmall H that have 9 speed transmissions. One has a lever on the left hand side of the clutch housing to operate the 9 speed shifter, the other H has a cable that runs thru the top right rear of the clutch bell housing to operate the 9 speed shifter. Both were referred to me as M&W 9 speeds. I don't know what or if there is a difference but something you might need to know if you call around for parts. Hopefully someone with Expertise will chime in and clear this up.
