Posted 7/18/2008 15:54 (#417851 - in reply to #417771) Subject: RE: Massey Ferguson 5465 ????
They are the same as the LT series but the LT series only has 2 models now, the LT85a and LT95a with SISU diesel engines. The MF 5400 has a wide range of HP with Perkins and Sisu diesels in the mix.
Posted 7/18/2008 20:47 (#417986 - in reply to #417851) Subject: RE: Massey Ferguson 5465 ????
SEIA
5465 if it is a Tier III motor will have 6 cylinder (402 cu.in.) Perkins, 100 pto hp. If it is a Tier II or older it will be 95 hp with 6 cyl Perkins as well. Should be miserly on fuel. If it has Dyna-4 tranny, that's a plus, fairly easy to shift and no clutching to change ranges.
