Search Forums | Classifieds (1) | Skins | Language
Cat C12 loosing prime/running rough after starting
golfnut
Posted 10/3/2015 20:17 (#4821793)
Subject: Cat C12 loosing prime/running rough after starting
Central Nebraska
I've got an '02 Freightliner Columbia with a C12 in it.  It has 510,000 miles on it.  I put a boatload of money into little nickel and dime things this Spring and ever since then I've had issues with it.  When I start it in the morning, or after it has set for an hour or two, doesn't run right.  It will idle just fine but when I try to accelerate it will sputter and blow white smoke.  After 10-20 seconds (occasionally longer) it will start firing on all cylinders and run fine until the next shut down.  Also, it doesn't do it every time.  Probably 75%.
It started after I had them repair the engine brake.  If I recall they replaced the injector harness (sounds suspicious?).  I took it back and they said the hand pump was leaking and I was loosing prime so they replaced it and it ran fine when I took it home.  Dad drove it this summer with the tender trailer and I did some too and I got preoccupied with spraying that I forgot about it.  Now it seems to be getting worse.  What will they find when I take it back in?
Scheller Farms
Posted 10/3/2015 20:51 (#4821886 - in reply to #4821793)
Subject: RE: Cat C12 loosing prime/running rough after starting
There are check valves in the filter base that are leaking fuel back. They unscrew as a unit and install new ones. If that doesn't fix it some have a check valve to hold fuel psi in the head on the rear of the head. May be leaking by. See if that helps you out!
4WD
Posted 10/3/2015 21:29 (#4821980 - in reply to #4821793)
Between Omaha and Des Moines, 7 miles South of I80
golfnut - 10/3/2015 20:17
Your mechanics need to get some sight glasses on the fuel "supply" and fuel "return" lines and see "WHERE" air is getting into the fuel system and trouble-shoot from there.
Yes, there is a possibility that you might have a problem with "fuel return check valve" (# 5 in photo) but normally a fuel pressure test will determine if that tends to be the culprit (meaning with a mechanic's mechanical fuel pressure gauge installed, and run engine; then shut off engine, then fuel pressure "should be" trapped (=if you have a good fuel return check valve AND a good fuel hand priming pump) The trapped fuel pressure will probably read at least 50 psi; with engine just being shutdown. {If it drops immediately to 0 psi, then try a new fuel return check valve(#5) and retest.
(sight glass troubleshooting tools.png)
(c-12 fuel fitler base photo.jpg)
Attachments sight glass troubleshooting tools.png (11KB - 1444 downloads)
Attachments c-12 fuel fitler base photo.jpg (77KB - 1102 downloads)
Bigboyfloyd
Posted 10/4/2015 06:52 (#4822295 - in reply to #4821793)
SW Michigan
The C12 in our lexion 585r was doing that and it was a bad fuel lift pump, I think that's what it was called anyway. Mounted on front bottom side of motor.
