St. Joseph, Champaign County, IL | Would add to the above, you're supposed to be stopped, no movement of the tractor, when shifting between any of the ranges, and use the clutch. Some persons say they can shift the ranges while moving without causing any damage. I'm not saying they can't, but that's not how it's supposed to be done according to Deere. To shift through neutral, when going from 2nd gear to 3rd gear (or 3rd to 2nd), you use the clutch, but the tractor can be in motion.
In essence, you select the range you want for the task at hand while the tractor is sitting still. You then can shift between any of the 4 forward gears (or 2 reverse gears) in each of the 4 ranges, while the tractor is moving. Can't shift between forward and reverse without stopping the tractor, though.
Reverse gears aren't available in D range. |
