s.e. Pa | I didn't even know they made a 1441 until this post. 1431 is hard enough to move around on our little roads. Do you have much road travel, it would be something to thing about. I was mower shopping this winter and the salesman told me that steel was more durable, but that rubber was quieter and conditioned better. He said because the rubber rolls ran closer, it crushed more hay. Not sure if that is true or not but I found a good used one and ended up with rubber. How do the steel rolls look? When they wear out, chunks start coming off. NH are pretty simple mowers, and easy to work on. As long as the 1441 isn't totally trashed, the steel rolls look alright, you don't have difficult roads to travel, and enough power, I'd look at it. I'm not that familiar with wheel rakes. I borrowed a 10 wheel before, and it seemed like it raked ~24' or so. 2-15' passes would probably work for a 12 wheel, because the swaths will be a good bit less than 30'. How are the prices? Here a 1411 brings the most, and a 1431 with straight hitch that has set outside some and looks a little rough might bring $6-7000 or so.
Josh | |
