Best skidloader tree puller attachment...
CRJ
Posted 5/12/2015 18:05 (#4566352)
Subject: Best skidloader tree puller attachment...
NEIN
Anyone have one they like or think is the best? I have some CRP to de-tree and I am thinking of buying one. There is one in the AgTalk classified but I think it looks kinda light weight and not gusseted well. It is one of the cheapest I have found so far though. Thoughts and experiences?
Joe@RFDG
Posted 5/12/2015 18:37 (#4566389 - in reply to #4566352)
Subject: RE: Best skidloader tree puller attachment...
Glenwood, Mn
I have the scissor type from Jenkins out of Long Prairie MN. I have it on a 450 ct (90ish HP) and have yet to tear it apart. I know they advertise here so it may be the one you are referring to.?.?. My brothers and I helped one of their father in laws clean up 300 acres of CRP with it. Invaluable tool as it gets the roots and all.
They used to do some custom fab so if you think you want something different or custom, I bet they could help you out.
Philbert
Posted 5/12/2015 19:13 (#4566449 - in reply to #4566352)
BENTON, MO
We got ours from CLFaf.com.  Its built stout, but we did manage to break it.  Sent it back to them on their dime and it came back to us better than new.  A weld was done wrong when it was made.  Only recurring problem has been breaking a hydraulic fitting.  We are very satisfied.
Iowa_STO
Posted 5/12/2015 20:16 (#4566585 - in reply to #4566449)
southern IA
Philbert - 5/12/2015 19:13
We have the EZ Puller from CL Fab as well. The only problem I've had with it is I didn't keep an eye on the hoses and they fell between the puller and the bucket arm and it cut one hose. Got about 40 acres of wetlands to clear and some of the trees are BIG. I'm using a New Holland L185 and I have pulled trees up to 14" diameter with it. When they get that big I dig at the roots and then I can up-root the tree. The last one was so big I couldn't pick it up and had to drag it to the pile. The biggest feature that I think is critical for a tree puller is the ability to dig in the dirt to get to the roots. CL Fab puts heavy guards over the cylinder to protect it for just that. The thing is worth every penny.
wire farms
Posted 5/12/2015 19:31 (#4566484 - in reply to #4566352)
Nebraska
I see Notch mfg. out of lake henry MN makes one now. We have a notch grapple bucket that it built very heavy, almost too heavy, so I would assume their tree puller is just as good.
datyerdog?
Posted 5/12/2015 20:13 (#4566576 - in reply to #4566352)
Harleman mfg. builds a nearly indestructible tree puller. We have one on our 7810 Gehl with 100hp. No problems yet after hundreds of trees.
(image.jpg)
(image.jpg)
Attachments image.jpg (103KB - 193 downloads)
Attachments image.jpg (66KB - 167 downloads)
Big Square
Posted 5/12/2015 23:21 (#4567008 - in reply to #4566576)
Eastern Half of Kansas
I will second anything Ron builds. He builds to last, if there is a problem, no question he's there to resolve it.
MidMOfarmer
Posted 5/12/2015 21:24 (#4566752 - in reply to #4566352)
We have a Precision Mfg tree puller. Model 525. It's built very well and has pulled a lot of trees. On the bottom side where the latch pins go through, the steel is a little thin and after a lot of use it cracked. We beefed it up and should be good to go now. I'm sure the company would have taken care of it but it was easier to just do it rather than ship it off or haul it back to the factory. The rest of it has held up well so far. I put some value in how much a skid steer attachment weighs. Just because it's heavier doesn't guarantee it's better but there's a good chance that more metal means stronger. This one weighs 498lbs but I don't know what others weigh. We didn't shop around, we knew a couple people that had them and liked them so we went with it. They are made in Missouri but I think they have dealers spread out everywhere.
Cadillacfarm
Posted 5/12/2015 21:33 (#4566784 - in reply to #4566352)
North Central Missouri
Got precision tree puller too. Great tool. Most used.
JoeR
Posted 5/13/2015 01:46 (#4567093 - in reply to #4566352)
NW Iowa
Neighbor has a Jenkins I've used to pull a lot of trees this spring with an l180. Very stout. I ended up buying a skeleton grapple from them and have been very happy with it. Honestly they are about the cheapest place to get one. I've pulled 5-6" diam trees with it.
CRJ
Posted 5/13/2015 05:59 (#4567160 - in reply to #4567093)
NEIN
Can you dig at the roots with it like CL Fab one can? And the forks are a lot longer than all the others I have seen, is that good or bad? Thanks!
ZR900
Posted 5/13/2015 08:03 (#4567401 - in reply to #4567160)
North Central Ia
I have a Lakender (sp?) I bought down by Iowa City. Put adapters on it it and use it on the front of my 200 hp FWA tractor loader. I'm sure it wasn't designed for this but has stood up fine. I've done things with it I'm not proud of and it stood up to the task.
stau40
Posted 5/13/2015 09:15 (#4567521 - in reply to #4566352)
Southern MN
Another vote for CL Fab. Bought the Tree Puller/Grapple this spring and zero complaints. It's nice to have the grapple built in to the tree puller so you aren't changing attachments all day.
