Eastern Iowa | #1 dipstick is in back under cab #2 Screen is to the rear of 2 Hyd. filters on side of case. Plug will be 1/2 inch square drive or a hex. Remove plug pull screen out. #3 Change filters and be sure to get o-rings for the housing. 2 filters, 1 is main one is power shift. #4 make sure coupling is not spinning on front pump shaft, Check for flow from line that feeds front pump, It runs along left side of frame rail, disconnect before the valve body under battery box, should put out a steady flow of oil during a very brief startup. You should get like 3 to 4 gallons in 20 seconds. Check same line for flow after valve body. There are ports on valve body that can be used for checking pressures, low pressures can indicate internal leakage but first you need to know the front pump is being supplied with oil. |
