Search Forums | Classifieds (2) | Skins | Language
Low Priced pintle hitch plate for a semi
Barker
Posted 4/17/2015 12:13 (#4521285)
Subject: Low Priced pintle hitch plate for a semi
WC Indiana
Here's a picture of a pintle hitch plate for a semi. I looked everywhere to find one and Illiana truck parts found these for around $250. Jerry at Illiana said if they just bought the 1/2" plate of steel it was $400. This $250 plate was already pre-drilled and came with d-rings and a light plug hole. Ended up making a real cheap tender trailer. Bought the used trailer for $2500 and will probably have $500 in the hitch after I pay Illiana to install it.
Edited by Barker 4/17/2015 12:15
(pintle hitch right.jpg)
(tender right.jpg)
Attachments pintle hitch right.jpg (142KB - 1083 downloads)
Attachments tender right.jpg (103KB - 710 downloads)
bharzman
Posted 4/17/2015 12:45 (#4521322 - in reply to #4521285)
Subject: RE: Low Priced pintle hitch plate for a semi
North Central Kansas
how does he get by getting so cheap?
pete37921x
Posted 4/17/2015 12:53 (#4521336 - in reply to #4521322)
NE SD
The pintle hitch is VERY light. Sure wouldn't trust nor is it correct for that ring on trailer.
Barker
Posted 4/17/2015 13:30 (#4521383 - in reply to #4521336)
WC Indiana
The pintle I bought was rated for 30,000 lbs and he spec'ed the plate for 30,000 lb. They also put in several braces and gussets to the plate.
pete37921x
Posted 4/17/2015 14:44 (#4521455 - in reply to #4521383)
NE SD
sorry that bolt diameter and small blot pattern lead me to believe different.
The hitch is stamped 15t ?
I have no idea what formula they think to spec the plate at.
Stacy
Posted 4/17/2015 15:02 (#4521476 - in reply to #4521336)
Triplett / Brunswick MO / Brookfield
It might be fine, but we've never had one put on that was as light as the one pictured. The ones we use are 1" plate. They also have bigger bolts.
Edited by Stacy 4/17/2015 15:03
1586
Posted 4/17/2015 13:05 (#4521352 - in reply to #4521285)
It looks like a 7-Ton pintle?  If you change your mind and want something different Blue Jet makes this hitch and has both single and dual spade hitches for hauling big stuff.  I searched for pintle to handle a big grain cart and they are not existent.
Barker
Posted 4/17/2015 13:31 (#4521384 - in reply to #4521352)
WC Indiana
Pintle was rated at 30,000 lbs.
Barker
Posted 4/17/2015 13:32 (#4521386 - in reply to #4521352)
WC Indiana
That does look nice but probably more than $250
