Michigan - Saginaw County | I did that job for years as a boy on a McCormick baler pulled behind a tractor - big old steel wheeled Case that ran on PowerFuel.
Yes, you inserted the wood dividers by hand - if you were slow about it you got a really big bale; sometimes a hundred pounds.
That also got you a butt chewing from the guy loading the hay wagon - which as I got older included me.
And you twisted the wires by hand.
It was busy but I don't remember it being back breaking. Hot, dirty, itchy, and deafening, though.
Loading the wagons and then throwing the bales up into the mow and building the stack was back breaking work - in June/July heat inside of a barn with no fans to move air. As the stack got higher you had a man standing about head high above the wagon load. The wagon man would hook the bale, pull it onto his knee then spin it upright and push it up into the air high enough for the middle man to hook it. He did the same so the mow man could hook it, carry back into the stack and place it just so. That was some 65 years ago.
Then during the winter I got to hook the bales again, drag them to the edge and drop them to the floor of the wagon aisle of the haymow. Drag them inside to the cows, break them open and spread them in the mangers - twice a day. You could say that like wood heat, the hay bales warmed me more than once. |
