Leeds, North Dakota | Jon, with so many variations of Cummins engines does engine have piston oil nozzle coolers ? block will have to have them, now we get to the fun part, you need to find a donor engine and a Cummins man that has the knowledge and willing to help. Need cpl off both engines, Cummins has the spec's, turbo, pistons, heads, it all matters, camshaft. Not as easy as it sounds, counter bore, Cummins has a setting of liner protrusine, shims are available different thickness, use original ones if you haven't mixed them up, need a depth mic to check. if both engines use a offset key for cam, Cummins tells you what direction of cam key is installed, yes they are offset, arrow stamped on key. Setting cam follower timing, you will need a Cummins tool, NO way to time cam any other way, this is not for a novice, done it many times, its time consuming, gaskets come in different thicknest, I always measure original and start from there, have I confused you yet, got questions, give me a call, Scott. | |
