Black Machine Parts
W.IL.Ag.
Posted 1/28/2015 17:56 (#4345383)
Subject: Black Machine Parts
Greenfield, IL
Anyone know of a salvage yard that has black machine planters. There are several odd/unique wheel lift cylinders I can't find anywhere. $1600 bucks from agco. The whole planter isn't worth $9000. Hard to swallow that much for a simple wheel lift cylinder!
Thank you.
CardotCustom
Posted 1/28/2015 18:23 (#4345460 - in reply to #4345383)
Subject: RE: Black Machine Parts
Western NY
You can't rebuild it?
W.IL.Ag.
Posted 1/28/2015 22:13 (#4346266 - in reply to #4345460)
Greenfield, IL
It was cracked.
CardotCustom
Posted 1/29/2015 12:59 (#4347327 - in reply to #4346266)
Western NY
You don't have a hydraulic shop around that could build a copy? I use a shop called Fluid Power near Buffalo, NY to get parts such as rods/body/seal kits that I put together. They do complete custom cylinders, I just don't pay them to do mine because I can do it cheaper.
blueraid
Posted 1/28/2015 18:26 (#4345468 - in reply to #4345383)
Southern Middle Tennessee
We were in the same situation a couple years ago. It couldn't be rebuilt and we wound up having to spend 600 bucks for a new cylinder. Good luck
dixonman
Posted 1/29/2015 05:36 (#4346459 - in reply to #4345383)
Herb, the planter guy at rankin Il would probably have one, Deere would be that much on similar cylinder, might check with Baum hydraulics also as pre agco black machines likely used cylinders that were available.
