Napa synthetic oil
Discblade
Posted 1/19/2015 18:04 (#4323488)
Subject: Napa synthetic oil
Southern IN
Went to Napa today to get oil, my wifes car needed changed.  I have been a solid mobile #1 customer for many years, though today they had their napa brand on sale for quite a lot less than the mobile.  I went ahead and bought the napa, anyone else use it?  Bottle says its made by Ashland, in Ky.  That is the same outfit that produces Valvoline, isn't it?
tj_farmer
Posted 1/19/2015 18:16 (#4323503 - in reply to #4323488)
Subject: RE: Napa synthetic oil
NW central IL
was always told napa and Valvoline are bottle at same place, if its the same, who knows. I wouldnt shy way from napa syn. oil
steerstopper
Posted 1/19/2015 18:19 (#4323508 - in reply to #4323488)
Been using it for a couple of oil changes so far so good.before that was using walmart super tech .I often wonder if a cheap synthetic is as good or better than a name brand conventional
PatCMO
Posted 1/19/2015 18:34 (#4323541 - in reply to #4323488)
Pilot Grove, Missouri
I used it for awhile, never had any problems. Get Most of my oil from Schaeffers now. Patrick
Antique Ray
Posted 1/19/2015 18:43 (#4323571 - in reply to #4323488)
NWIN
About a year ago I was talking to the oil salesman where I work,I gave him a sample of Valvoline 5w-30 and NAPA 5w-30 synthetic oil and he had there lab test them, they came back as identical.
codydfarms
Posted 1/19/2015 19:52 (#4323756 - in reply to #4323571)
Napa is re-bottled Valvoline
Jon Hagen
Posted 1/19/2015 20:10 (#4323826 - in reply to #4323488)
Hagen Brothers farms,Goodrich ND
You can usually find who makes an oil product by searching for the products MSDS sheet online.
Napa synthetic is made by Ashland, their logo is on the MSDS sheet.
http://s7d9.scene7.com/is/content/GenuinePartsCompany/725928pdf?$PD...
It is a hydrotreated mineral oil, so I believe it is a synthetic using grp 3 base stock oil.
My Dakota pickup needed an oil change yesterday, so I used Toyota 0W-20 full synthetic I had on the shelf for a couple of years. The Dakota has run most of it's life with Mobil 1 0W30 in it, so I suspect the Toyota 0W20 synthetic will do just fine as it is winter plus the pickup is never heavy loaded.
I suspected since Toyota changed synthetic oil suppliers in 2011, that it was relabled Mobil1 as they use that distinctive shape Mobil jug, but using black plastic instead of Mobil's grey.
I checked the Toyota synthetic MSDS yesterday after doing the oil change. Yep , the specs are identical to Mobil 1 and the Exxon Mobil logo is in the upper right corner of the Toyota MSDS sheet. It appears that Toyots synthetic / Mobil 1 are still made from PAO grp 4 base stock oil.
Edited by Jon Hagen 1/19/2015 20:15
801486
Posted 1/19/2015 21:21 (#4324118 - in reply to #4323488)
west central Iowa
I used it and thought it was fine, but if your Napa is like my local Napa you better stock up the once a year it is on sale, the rest of the year it is higher than Mobil.
BachRstFrms
Posted 1/20/2015 07:41 (#4324656 - in reply to #4323488)
Southern MD
I had always ran Mobil 1 synthetic in my 1500. About a year ago guy working at napa said why don't you try napa synthetic it's valvoline oil? It's $3.30 a qt so I tried it. Been using it ever since. Seems to run a tad less oil pressure at operating temp but truck has 215k n still doesn't burn or leak oil in 5k oil change. He also showed me a new quart of napa oil they had kept that a valvoline cap put on it at plant.
Discblade
Posted 1/20/2015 11:27 (#4325161 - in reply to #4324656)
Southern IN
Thanks for all the responses.  It looks like it is a pretty good oil.  I found an oil test online performed by amsoil, comparing their product to other top brands.  The valvoline syn ( or napa) looked pretty good in these tests.  The test left out straight mobile 1, but did have mobile 1 extended performance.  The valvoline performed a good bit better in amsoil's lab.
     Since you all have had good luck with it, and that amsoil test looked good, I think I will take the advice to stock up some.  $3.79 a quart is a pretty good deal for synthetic.
forward
Posted 1/20/2015 10:05 (#4325015 - in reply to #4323488)
NoDak
I may be a little biased, because my family owns the local Napa, but it's all we've ran for 30+ years with no problems. The synthetic (and probably most brands syn) exceeds GM's standard for the new vehicles that require dexos, so don't believe the dealer that you need to run the AC Delco stuff if they try telling you so
