6410 deere fuel injection pump removal
bsfarms
Posted 12/2/2014 09:17 (#4214653)
Subject: 6410 deere fuel injection pump removal
south central WI
6410 is missing bad on one cylinder. I replaced the injectors about 3 years ago, maybe 2000 hours ago. Tractor has around 10000 on it now. I will remove pump and injectors and have shop look at them, but they always say everything is shot and repair anyway. Lol Never done one on a deere so any tips? Easiest way to set at tdc and remove the pump. Any special tools? Looks straightforward but want to make sure I don't screw something up. Thanks.
bsfarms
Posted 12/2/2014 09:21 (#4214663 - in reply to #4214653)
Subject: RE: 6410 deere fuel injection pump removal
south central WI
Also I can't even start it when it is cold, plugged in or not. I had to roll it into shop today to warm it up and it still won't start. Lift pump is prob bad also as I can't hear it. Last time it went out it was very random on power. It would be fine then lose power. This is a solid and non-variable miss always on one cylinder.
bsfarms
Posted 12/2/2014 11:26 (#4214869 - in reply to #4214663)
south central WI
Lift pump had fallen off. Reinstalled it and it pumps fuel to inj pump. Cracked all 4 lines coming out. Fuels sprays from 1,;drips from 2 and nothing from 4th.
Billyfox
Posted 12/2/2014 13:00 (#4215024 - in reply to #4214653)
BC, Canada
Do you have it running now? Just has a bad miss? Or is the fuel from 1, drips from 2/3, nothing from 4 all at cranking? Can you isolate which cylinder has the missing by craking injector lines with it running.
bsfarms
Posted 12/2/2014 15:28 (#4215234 - in reply to #4215024)
south central WI
I managed to get the pump off. This style pump you have to pull pump out and the gear stays in.  It is keyed so will only fit one way.  Service man said mark the gear and case to make sure it doesn't shift.  The other style pump he said the shaft stays with the gear and the pump is pulled off the shaft.
It is the 2nd cylinder that pumps.  I even tried cracking the lines at the injectors to see if it was maybe an air lock somehow.  It still only sprayed from that line. I have injectors removed also. When it ran it seemed to only miss on one cylinder.  We perked it and now it wont start.  Right before I removed inj pump I tried starting again.  It had been inside heated shop for 4 hours AND plugged in.  Engine was very warm to the touch.  It still wouldn't even pop, not even the one cylinder.
This tractor also cranks over too slow when cold.  We have tried new batteries and cables.  Only thing left is the starter, correct?  You can put a charger or jumper cables on it and it still only turns over at half speed.  Sometimes it will crank fast but not often or for long.  Battery is Deere and a year old or maybe 2.
