We had this Rice Lake scale installed in 2010. Works great for us. Has dump-thru grate on it, pit is below the scale. Photos below. Rice Lake custom builds scales to your needs. Semi pulls on the scale & stops w/front hopper centered over pit. All wheels are on scale deck (deck is 80', I believe). Driver exits truck & records loaded weight. Front hopper is dumped. When front hopper is empty, driver moves truck ahead so rear hopper is centered over pit grate (we use a light/horn detector system to mark "stop" spots) and all wheels are still on scale. Driver (or attendant) dumps rear hopper. Without moving truck again, the e.w. is recorded. Driver exits w/empty truck. So, only 1 move is required after truck arrives on scale loaded. It works well & I'd not make any major changes in the system. The scale grates have a rubber flap "funnel" that directs corn into pit, so there is actually no scale portion or corn that touches the pit. Even though the pit could be full, the truck scale weight is correct...they don't touch. We weigh every bushel of corn that goes thru our dryer. With our system, whoever is dumping truck controls all unload functions (except moving truck ahead....working on that idea!), from the confines of the scale house. The red light you see above the windows of the scale house are an external weight read-out. Scale has printer system inside the scale house. |
