Search Forums | Classifieds (92) | Skins | Language
series parallel switch.
terminater3406
Posted 11/11/2014 22:26 (#4172476)
Subject: series parallel switch.
Wisconsin
We have a 68 kW with 24v series parallel switch. When we hit the start button the series parallel switch just clicks or buzz constantly. I took the wire from the parallel switch that sends signal to tell starter to turn and put in a toggle switch to try and bypass the parallel switch. I got the starter to turn over but it kicks out breaker or relay. Does anyone know how to bypass the parallel switch? Or can I even do that? Please help were trying to finish up corn and need this truck as our only other truck will have to be hauling corn out of bins to make room.
Thanks!
hillfarmer
Posted 11/12/2014 04:24 (#4172599 - in reply to #4172476)
Subject: RE: series parallel switch.
just put a MT 40 on it use a couple 12 volt in parallel
if a cummings, it would have a decompression lever ,to help get it to roll over
My 62 will start at 30 with one battery because of the decompression lever
4WD
Posted 11/12/2014 06:46 (#4172729 - in reply to #4172476)
Between Omaha and Des Moines, 7 miles South of I80
Here's a photo/schematic from the internet:
http://www.texasindustrialelectric.com/T_114_12_series_parallel_switch.asp
T-114-12 12/24 Volt Series Parallel Switch Relay
Cranking at 24 Volt & Charging on 12 Volt
Used on Marine & Industrial Applications.
Can Be Used For Starting System For Turbine Engine
Texas Industrial Electric has been servicing customers in the
San Antonio Texas and surrounding area since 1981.
Please take a look through our web site, and feel free to
contact us if you have any questions .
Click Here For Battery Isolators And DC to DC Equalizers Information,We Are Updateing Our Web Site Please keep Checking Back Thank You !!
Click Here to View Electrical Information,We Are Updateing Our Web Site Please keep Checking Back Thank You !!
Click Here to View Speedometer Cable & Ratio Box  Information,We Are Updateing Our Web Site Please keep Checking Back Thank You !!
Custom length Battery Cables made to your order
Click Here to View Starter Information,We Are Updateing Our Web Site Please keep Checking Back Thank You !!
Circuit Protection Devices Self Resetting Circuit Breakers From 10 to 150 Amp.
12 volt and 24 volt, 80 amp to 200 amp Momentary and Continuous Duty type Relays
universal ignition switches,heavy duty toggle switches,push pull type switches
Click Here to Vist Our Electrical Components Area. Electrical Plugs, Special  Electrical Connectors  & Wiring Parts.
Electric Fan Relay Wiring Kits,Thermostat Switches For Electric Cooling Fans.
Click Here to View Specials Information,We Are Updateing Our Web Site Please keep Checking Back Thank You !!
12/24 Volt DC Series Parallel Switch.
Click Here For Line Drawing Of the T-114-12 Series Parallel Switch
T-107-24 24/48 Volt Series Parallel Switch Relay
Heavy Duty 8 Terminal Series Parallel Switch
2 Normally Closed Circuits
1 Normally Open Circuit
Can be used to Control 24 Volt Bow Thrusters on large Boats a 1119865CD may be required .
Extended Duty Applications Will Require Use of The SCM ( Solenoid Controller Module).
Cranking Systems on 24 Volt & Charging on 12 Volt
Voltage: 12/24
Coil: Insulated Circuit
Rated at 1500 amps Intermittent Duty.
175 Amp Charging Circuit
Contacts : Silver
Relay Battery Terminal Studs 3/8 x 16
Coil Terminal studs 10x32
Can Be Used To Replace Leece Neville 5155S
Click Here To Return to The  Relay Area.
Click Here To Return To The Home Page.
Texas Industrial Electric Co.
11116 Watt Circle
San Antonio Texas 78233
Phone 210-654-4075
Fax 210-599-2843
We accept American Express, Master Card, Visa & Discover
E-mail : [email protected]
Alternators - Starters Electrical Speedometer Drive Accessories Links
Edited by 4WD 11/12/2014 06:48
GM Guy
Posted 11/17/2014 20:11 (#4184336 - in reply to #4172476)
NW KS/ SC ID
I have a buddy I help part time, and he has close to a dozen old vintage KWs. the 1970 with the cummins has the series/ parallel switch act up. we got through harvest pulling the decompression lever, and then he found a new switch on ebay, and it has been running flawless since.
If everything has worked fine till now, I would honestly put a new switch on and keep it as is. 3-4 of my buddy's KWs have the switch, and this is the first one to act up, it is a pretty reliable system IMO.
terminater3406
Posted 11/17/2014 20:17 (#4184370 - in reply to #4184336)
Wisconsin
GM Guy - 11/17/2014 20:11
Is your buddy looking for another? This one is for sale.
