Posted 10/14/2014 21:54 (#4127011 - in reply to #4126079) Subject: RE: Chart or App for drying Grain
Google equilibrium moisture moisture content. As a general rule, if moisture is not excessively high and you want to dry,run fan at under 60%humidity. If moisture is excessive run fan or it will get hot. If grain is dry, run fan at night to cool. Some people and equipment manufacturers put grain in and run fan until grain is dry, regardless of outside conditions and this method works also.
Posted 10/14/2014 21:59 (#4127029 - in reply to #4126079) Subject: RE: Chart or App for drying Grain
west central IL
I use an Iphone app called Hygro. It just shows what the current humidity is at your location. If needed I'll run them under 50 or 60% and shut the fans off if over 60.
