PTO will do nothing at all on this tractor. About 2 sec. after turning switch, idiot light on dash starts flashing and that is all that happens. I replaced pto switch, pto speed sensor and electric selenoid. Read thru some old posts and find nothing else. Local dealer seems too busy to call back. Anyone have some more suggestions? Thanks
Posted 5/13/2014 20:02 (#3868654 - in reply to #3868550) Subject: RE: JD 6410 pto
collins ny
had one that would start then stop. pull the shaft out there a little nob on the end that pushes on a button inside the tractor. it was whore down so it wouldnt push the button. we put a dab of weld on it work good now .
Posted 5/14/2014 04:47 (#3869183 - in reply to #3868775) Subject: RE: JD 6410 pto
Wangaratta, Victoria, Australia
Ours was a computer problem had it sent away and repaired seems fine now. Only way to work it out is to replace the switch then the Pto speed sensor above the Pto shaft and then the computer behind the panel under right hand console
