Middlesex County, Ontario | SEMO.
The system I am familiar with does not have buttons in the cab. All you can do from the cab is turn the PTO on/off. To change speeds you have to get out, get your pliers, remove the snap ring, and flip the stub around. Flipping the stub around engages a pin inside which changes gears. This is similar to the 10 and 00 series.
The in cab shiftable models: on the side console there are three buttons in a triangle formation. One with an engine, one with a gear (transmission) and one with a PTO. If you don't have the PTO button in that triangle you must have the "get out and flip the shaft" style. Here is a picture of that button and the screen shows where you would be able to shift your pto. http://manuals.deere.com/omview/OMAL171299_19/OULXE59_001095F_19_03...
With a $70 over run clutch like used when mowing with an old tractor he will have no problem spinning the shaft with a couple fingers. The implement will not brake on the PTO when powering down and will coast when letting the throttle down. Those might be (safety) issues, your call.
Example: http://www.ebay.com/itm/NEW-TRACTOR-OVER-RUNNING-COUPLER-PTO-OVER-R...
Edited by WildBuckwheat 5/4/2014 15:42
