Does anyone know if swapping a complete front axle assembly from an 8640 into an 8630 is possible. Neighbor has a parts 8640 tractor and I have some major problems in my 8630 front axle. I know its different size axle shafts inside but was wondering about swapping complete assemblies and gear ratio.
Posted 3/30/2014 12:56 (#3786040 - in reply to #3786018) Subject: RE: 8630 8640 Deere front axle swap
Doesn't the 40 series axle use lube lines for the front pinion were the 30 series does not ? I would think the tech manuals for each tractor would give the diff ratio's for each tractor.
Posted 3/30/2014 21:22 (#3787153 - in reply to #3786018) Subject: RE: 8630 8640 Deere front axle swap
The 8640/50 share gear ratios with 4840/50 and 4955/60 where the final drives are concerned. The 8630, 8440/50 and 4630/40/50 and 45/4755 and 45/4760 have similar components. Both the 8430 and 8630 have dedicated gear lube in front axle. All others common lube from rear end. Hope this helps.
