Search Forums | Classifieds (3) | Skins | Language
8235R codes , what do they mean
John..neAR
Posted 3/21/2014 19:59 (#3767894)
Subject: 8235R codes , what do they mean
Caraway, AR
523329.14  redundancy loss due to component fault. Vehicle with restricted function.
522790.03 Primary hydraulic pump pressure sensor 1 circuit fault.
Acu.001     code 522149.14
9th gear is fastest gear it will run in. Autosteer works and  everything else seems fine.
Was doing good when it was parked.
Thanks, John
Justin ArkMo
Posted 3/21/2014 20:13 (#3767930 - in reply to #3767894)
Subject: RE: 8235R codes , what do they mean
The Delta
Had the same issue on one left outside during a hard rain. Legacy Corning knows the fix and I want to say it had something to do with water inside the implement light connector on the rear, crazy as it sounds?
John..neAR
Posted 3/21/2014 20:19 (#3767943 - in reply to #3767930)
Caraway, AR
Thats good because it came from Legacy and it's in warrenty.
Thought if it was something simple I might save them a trip.
I'll look at  that connector tomorrow.
Thanks, John
deererammer
Posted 3/21/2014 20:19 (#3767941 - in reply to #3767894)
I would check the connections on the harness on the right hand side. Between the inside tire and the rear end housing. There is a block with three or four sensors in it located there. It has not been uncommon for those sensors to fail.
John..neAR
Posted 3/21/2014 20:21 (#3767950 - in reply to #3767941)
Caraway, AR
Will do.
Thanks, John
John..neAR
Posted 3/22/2014 11:12 (#3768850 - in reply to #3767894)
Subject: All is well
Caraway, AR
Very courteous and knowledgeable tech from Legacy came out this morning.
Changed the sensors y'all were talking about, I'm sure.
Thing runs like new (it almost is)>:)
John
