Search Forums | Classifieds (3) | Skins | Language
acre per hour chart
Ildoc1
Posted 2/10/2014 15:55 (#3679218)
Subject: acre per hour chart
Anyone know of a spreadsheet or chart that will calculate acres per hour with different speed and equipment width as variables?
Thanks
datyerdog?
Posted 2/10/2014 16:08 (#3679254 - in reply to #3679218)
Subject: Re: acre per hour chart
MPH X Width in feet X .1212 = Acres/Hour
Ildoc1
Posted 2/10/2014 16:46 (#3679330 - in reply to #3679218)
Subject: RE: acre per hour chart
Thank you!
flatlander2010
Posted 2/10/2014 17:00 (#3679365 - in reply to #3679330)
or mphx5280xwidthxefficiency(i like to use .9 to account for turns)/43560
WildBuckwheat
Posted 2/10/2014 17:00 (#3679364 - in reply to #3679218)
Middlesex County, Ontario
We always figure feet x mph = what you can get done in a 10 hour day.
Its not accurate as far as acres/hour at this exact moment. It kind of accounts for turning around, piss breaks, rocks.
Someone told me at 15' (6 row) kilometers per hour is close to acres per hour.
Tim in WI
Posted 2/10/2014 20:18 (#3680026 - in reply to #3679218)
Embarrass WI
I always use width in feet x miles per hour / Ten
Example 20 feet wide x 7 mph = 140 divided by 10 = 14 Acres per hour
This allows about 15-18% efficiency loss, it's not exactly accurate but works out pretty close in the real world.
This formula was one of the first things I learned off the internet "way back when". Give the credit to Plowboy.
Edited by Tim in WI 2/10/2014 20:19
pointrow
Posted 2/10/2014 20:50 (#3680172 - in reply to #3679218)
Central Il Morton
Width x mph /10 was used back in horse days and still is pretty accurate today.
good luck
pointrow
illinois-kris
Posted 2/10/2014 23:08 (#3680613 - in reply to #3679218)
Subject: Try this
IL
Send me an email if this attachment doesn't work, running Microsoft excel on windows 7. Made this up last summer. Plug in your numbers and it'll spit out the data. Went to tractordata.com to figure out the fuel consumption along with my own records.
Edited by illinois-kris 2/10/2014 23:14
Attachments Field Productivity & Efficiency.xlsx (12KB - 1472 downloads)
Illini Fan
Posted 2/10/2014 23:21 (#3680635 - in reply to #3679218)
Greene County, Illinois
http://farmdoc.illinois.edu/pubs/FASTtool.asp?category=farm
Scroll down and download the machinery economics. You can put in your own data.
Hayhauler
Posted 2/10/2014 23:30 (#3680644 - in reply to #3679218)
Northeast CO
SpeedXWidth/8.25= is the formula I use a lot
amhfarm
Posted 2/11/2014 08:08 (#3681031 - in reply to #3679218)
central IN
quick and easy is (speed x width)/8.25. That is for 100% field efficiency but just multiply by your true field efficiency % and you should be dang close.
Steve in SD
Posted 2/17/2024 12:41 (#10627434 - in reply to #3681031)
Northville, SD
Don't forget efficiency changes as field length changes.
lauratck
Posted 2/17/2024 11:45 (#10627365 - in reply to #3679218)
I'm only about a decade late but we've made an online calculator and lookup chart for just this. Anything you think we should change or add? The calculator is here: https://www.thecalculatorking.com/calculators/farming/acres-per-hour...
