Well I will give you the cheap part since I have no good rebuttal for that.=(:) As for the dangers, with the small amount of air we are talking about in this situation I don't belive it would be near the hazard of such things as air brakes with compressor oil that gets mixed and pressurized through the system or the air over hydraulic's that run everything from jacks to car lifts to cylinders in the industrial world. Add the thousands of miles of oil pipelines with air bound to be stuck in there somewhere. In this case if oil is coming out of the schrader valve it means the seal is shot anyway and no amount of air will keep it up. If no oil is coming out then the two won't mix anyway. In the end it's whatever you ar comfortable with.
Edited by sri 2/15/2008 22:42
