Search Forums | Classifieds (47) | Skins | Language
Who uses Accomplish LM ?
billybob
Posted 11/11/2013 17:36 (#3438214)
Subject: Who uses Accomplish LM ?
68340
It is called a biochemical fertilizer catalyst.   Dealer said they got an 11 bu. boost in corn yields.  I am going to have them apply a fall test strip on 11 acres of this years corn ground.
scitrader
Posted 11/11/2013 18:25 (#3438317 - in reply to #3438214)
Subject: Re: Who uses Accomplish LM ?
we have had several tests out on this product and it looks pretty good.
AGB
Posted 11/12/2013 05:34 (#3439178 - in reply to #3438214)
Mid-Michigan
I just asked this question a couple days ago. My Cps salesman is pushing it pretty hard. I think I'm going to try some.
Iroquoisfrm
Posted 11/12/2013 06:09 (#3439215 - in reply to #3439178)
It worked in 2011, did not in 2012, and it worked this year but have not printed yield maps to quantify.
Iroquoisfrm
Posted 11/12/2013 06:10 (#3439218 - in reply to #3438214)
However, i have always used it in the spring mixed with 28 % in the weed-feed.
Midwest18
Posted 11/12/2013 06:51 (#3439275 - in reply to #3438214)
I think it's great. Bacillus bacteria show many benefits. We ran it with 28. Just don't let them tank mix with Instinct.
AMSLIFER
Posted 11/12/2013 09:23 (#3439603 - in reply to #3439275)
Frisco, Texas
Midwest18, actually Instinct is a very good tank mix partner for Accomplish LM-(active ingredient is biochemistry)
2012 Corn data from Illinois-25 field trials showed very good efficacy when these 2 technologies are combined
Accomplish LM mineralizes organic N into inorganic plant available form Ammonium(NH4)
Instinct protects NH4 from Nitrosomonas bacteria
cyclonefarmer
Posted 11/12/2013 08:53 (#3439547 - in reply to #3438214)
Subject: RE: Who uses Accomplish LM ?
Northeast Iowa
We use a quart/acre in furrow with starter - did multiple tests for 2 years, always saw results so quick doing tests and just do every acre now.
isu50
Posted 11/12/2013 20:10 (#3440555 - in reply to #3439547)
North central IA
What's a quart cost per acre?
Midwest18
Posted 11/12/2013 19:55 (#3440517 - in reply to #3438214)
I agree that they tank mix well. I dont agree with mixing a bactericide "Instinct" and bacteria "Accomplish" in the same tank. That fertility program makes no sense. You're killing your bacteria in the tank. The Instinct bacteriacide label calls for tank mix with insecticides, herbicides, and fungicides.
Edited by Midwest18 11/12/2013 20:00
AMSLIFER
Posted 11/13/2013 08:32 (#3441540 - in reply to #3440517)
Frisco, Texas
Midwest18--you are correct, if the active ingredient in Accomplish LM were bacteria--mixing with Instinct would be a no no
however, since the active ingredient is biochemistry --mixing with Instinct does not impair efficacy of Accomplish LM
THANK YOU for your comments and concerns!
Scammer#1
Posted 11/15/2013 05:21 (#3445515 - in reply to #3438214)
West Michigan
I was wondering if any one used the Accomplish LM on hog manure or what are they seeing the yield bump in?? We have a finishing barn and didn't know if it would work in our system?? We run all not till. We have no-till injector when we apply to they ground with manure.
AMSLIFER
Posted 11/15/2013 12:25 (#3446086 - in reply to #3445515)
Frisco, Texas
yes, Accomplish LM at 2 qts per acre injected with hog manure has shown to bump yields about 5-7%--10-14 bushels in 200 bushel corn
are you using a honey wagon to inject the hog manure? If so, you can inject the Accomplish LM as you load the honey wagon.
AMSLIFER
Posted 11/15/2013 12:27 (#3446089 - in reply to #3445515)
Frisco, Texas
<p>if you would like to see 3rd party and field trial data-please send your email address thanks</p>
