SE IL | For about the last month our 2011 Case IH Magnum 340 has been throwing off an engine error code. When operating, the tractor loses power, the caution & stop light show on the A-post, and the tractor won't rev back up past about 1300 RPM. Once you restart the tractor, it will run fine until it does it again. It seems if you don't run full-throttle, you can work longer between faults.
Our Case dealer has tried numerous things but can't seem to fix it. Anyone have any experience or ideas?
Edited by chedv 8/5/2013 21:03
