Search Forums | Classifieds (23) | Skins | Language
Sukup power sweep
IowaNotiller
Posted 6/14/2013 19:00 (#3155428)
Subject: Sukup power sweep
Iowa
I came home today and looked into the bin to see how they were coming along. The power sweep is in and looks like this on the end. Where is the wheel? How does this go around the bin without tearing up the floor?
Edited by IowaNotiller 6/14/2013 19:05
IowaNotiller
Posted 6/14/2013 19:07 (#3155440 - in reply to #3155428)
Subject: RE: Sukup power sweep
Iowa
Try this again.
(100_2096.jpg)
Attachments 100_2096.jpg (82KB - 377 downloads)
johnny skeptical
Posted 6/14/2013 19:22 (#3155459 - in reply to #3155440)
n.c.iowa
walking drive!!! i haven't seen one of them in years,we built a behlen bin in '75 and the sweep that came with it had a walking drive on it,was a pretty good and dependable sweep but it wouldn't move itself around the bin too good,be interested if this rendition works better.
Downsizing
Posted 6/14/2013 21:30 (#3155705 - in reply to #3155428)
Subject: Re: Sukup power sweep
All the Sukup stuff I have is painted green when did they start using red and blue paint.
collegeboy
Posted 6/14/2013 21:39 (#3155731 - in reply to #3155428)
Slicker than a Yes album.
They make marks as the move along, but no more so than a spinning wheel. Ours I have to give a shove now and then, but I'm in there anyway shoveling and sweeping.
balefire
Posted 6/14/2013 21:45 (#3155743 - in reply to #3155428)
Oxford County, ON
That is the exact same setup that's in our top dry bin. Works very, very well, doesn't take off on you when it gets to the end of the circle like a direct drive wheel.
cordellh
Posted 6/14/2013 23:07 (#3155905 - in reply to #3155428)
do you have more pictures of this walking assembly? it really has me intrigued.
funfarmr
Posted 6/14/2013 23:16 (#3155921 - in reply to #3155428)
Ohio
Someone wanna explain how this works? I've never seen one before.
Five Lock Boll
Posted 6/15/2013 04:39 (#3156015 - in reply to #3155921)
Northeast Louisiana
Look closely at the middle of the 2 blue pieces. It's made like a crankshaft, making those 2 blue pieces take little baby steps around the bin.
funfarmr
Posted 6/15/2013 13:51 (#3156618 - in reply to #3156015)
Ohio
Five Lock Boll - 6/15/2013 04:39
Makes sense now. I noticed they were offset before but I guess I was over thinking how it worked.
mrsc
Posted 6/15/2013 06:40 (#3156076 - in reply to #3155428)
I have Brand new Sukup bin (December 2013)and the sweep looks nothing like that. It has a wheel and is green. I wonder if your bin dealer did a substitution to make his bid lower. I would check the sweep and look for a manufacturer plate. Then look at your bid to see how it was quoted.
ProCross
Posted 6/15/2013 08:03 (#3156183 - in reply to #3155428)
keep it greased! ours gets greased every single load. I like ours better than wheels and I'm working on converting all of our power sweeps to walkers. no worries
RYAN Farms
Posted 6/15/2013 08:22 (#3156218 - in reply to #3155428)
SW MN
The picture looks nothing like our Sukup power sweeps. But I like the idea better the Sukups rubber wheels that wear out. Has anyone converted a sukup to the walkers? Easy to do? Thanks
collegeboy
Posted 6/15/2013 22:17 (#3157259 - in reply to #3156218)
On our Sudenga, there is just two bolts that come out and the walker end slides in. Should all be in one piece. Maybe check with your dealer.
GangGreen
Posted 6/15/2013 08:42 (#3156248 - in reply to #3155428)
Eastern Iowa
Red/blue probably means Hutchinson/NECO. A little on the light side as far as power sweeps go, but at least it isn't roller chain driven. Manufacturers keep trying to find the right balance between traction and durability in effectively unloading grain. As far as I am concerned they haven't found it yet!
I did sell one of these today. A Daay paddle sweep. A different animal completely, but I sold it to a seed company who might empty a bin 4 or 5 times a year:
Performance has been excellent with these, they leave very little behind the back board to clean up. Paddle adjustment and wear will be the main issue, but they've held up nicely in commercial models.
Edited by GangGreen 6/15/2013 13:08
IowaNotiller
Posted 6/15/2013 10:54 (#3156416 - in reply to #3156248)
Iowa
It is a Neco model. I had not seen one like this before. Thanks.
