Search Forums | Classifieds (1) | Skins | Language
Cat Challenger MT975C vs. Quad Trac for Tiling?
Matt K
Posted 6/9/2013 11:17 (#3145685)
Subject: Cat Challenger MT975C vs. Quad Trac for Tiling?
Currently a local dealer has a 2009 MT975C with 800 metrics, we demoed it on our salford and we are pleased with it. We know the QT transmission's kick out sometimes while tiling. Just wondering if anyone uses a Challenger to pull there tile plow, how how they like it?
(975c.jpg)
Attachments 975c.jpg (36KB - 687 downloads)
johndeere430u
Posted 6/9/2013 11:19 (#3145691 - in reply to #3145685)
Subject: RE: Cat Challenger MT975C vs. Quad Trac for Tiling?
Central, mn
Friend of mine, run that tractor pulling their plow and love it.
scott nelsen
Posted 6/9/2013 12:14 (#3145782 - in reply to #3145685)
Subject: Re: Cat Challenger MT975C vs. Quad Trac for Tiling?
Leeds, North Dakota
Matt, put a Steinbauer chip on it, for tiling, working on two tractors right now, Scott.
Land_Surfer
Posted 6/9/2013 14:53 (#3146043 - in reply to #3145782)
Why would you need a power chip on an 18L engine rated at 585 hp (425 PTO)? Even a 13L with 15-20 more hp can't touch that kind of power from 18L.
Edited by Land_Surfer 6/9/2013 14:53
SJ@Farmacres
Posted 6/9/2013 13:06 (#3145879 - in reply to #3145685)
South Africa
Steinbauer chip for tiling on the Quad is amazing.
scott nelsen
Posted 6/9/2013 13:12 (#3145893 - in reply to #3145879)
Leeds, North Dakota
SJ@Farmacres - 6/9/2013 13:06
tell me more, Scott.
SJ@Farmacres
Posted 6/9/2013 13:39 (#3145951 - in reply to #3145893)
South Africa
Pulling a Gold Digger ZD behind the 500 Quadtac. Got fed up with no power in first gear and also no low down torque. Got the Steinbauer chip set for tile plow tractor, installed it last week. WOW! Different tractor, it will now spin all 4 tracks @ 1300 rpm in 1st! No more lugging down to 650rpm and kicking in to neutral (ps. It is was never the kicking in to neutral that was the problem, this only happens at 650 rpm to stop the engine from stalling, which actually helps a lot so you don't need to restart every thing. It is no power in the low gears thats the problem, but the steinbauer fixes that)
Jacob Bolson
Posted 6/9/2013 14:14 (#3145999 - in reply to #3145685)
Iowa
A local crew here pulled their QuadTrac off of the tile plow and replaced it with a MT9X5B.
nhermanson
Posted 6/9/2013 16:50 (#3146244 - in reply to #3145999)
Central, IA
+1. He's a die hard red guy, and won't go back.
bigfarm
Posted 6/9/2013 14:21 (#3146006 - in reply to #3145685)
I'm sure there's a way to modify the tranny in the quad so it doesn't slip, just need time and motivation. Maybe if they put a heavy duty and reliable cvt in there new Quadtrac 620 (that supposed to be coming out soon) it will fix things.
Edited by bigfarm 6/9/2013 14:27
jd8850
Posted 6/9/2013 14:29 (#3146019 - in reply to #3145685)
Roseglen, North Dakota
Whether or not someone likes/dislikes Agco/Challenger the C-16/C-18 engine is arguably the best engine out there--power and torque are second to none. Not hard to see where it would be awesome on that slow heavy pull.
Edited by jd8850 6/9/2013 14:30
Land_Surfer
Posted 6/9/2013 15:58 (#3146136 - in reply to #3146019)
And they don't need power chips to pull either.
If you need a power chip on a the largest, most powerful ag tractors in production, you need to re-evaluate the application or get a D8.
hobby95
Posted 6/9/2013 22:44 (#3147250 - in reply to #3146019)
SW MINNESOTA
Heard from challenger salesman today that this is the last year for CAT power in the 800 and 900 series tractors!!! Is this a good or bad thing?
3532
Posted 6/9/2013 17:36 (#3146329 - in reply to #3145685)
North Eastern ND
need chips on the quad because the power is derated in 1st gear and it powers out. just need to get over that obstacle using the chip to do so.
Jim Beam
Posted 6/9/2013 20:37 (#3146810 - in reply to #3145685)
Subject: Apples and oranges guys
Roaming the plains
You are comparing a tracked machine to tires.  A tire machine will slip on the tile plow where the tracks will not.  It's not a power issue but a traction issue.  AGCO, Case IH, and Deere manage the power in the lower gears, it's just that something has to give eventually so a tracked tractor has to due it mechanically where the tires will slip.
gpsdude
Posted 6/9/2013 22:06 (#3147143 - in reply to #3146810)
NE South Dakota Clark, SD
I have personaly never run a MT9xx pulling a plow. I love the MT8xx's though. I have talked to a guy that tried a quad and ended up with an MT 9xx. If they are geared like the tracked version, should be great.
