Just wondering what everyone runs across precast concrete J bunks? If you are just using the cables, or does bolting guardrail on work. I've been using cables, but they don't last very long. Other ideas, or pictures would be appreciated. thanks
Posted 5/20/2013 21:24 (#3108299 - in reply to #3108237) Subject: Re: concrete J bunks
MN
I got cable on mine...I think I would go with guard rail next time. You could probably bolt it on the cable posts but I know they make a special post for guardrail. The only thing I really like about the cable is being able to adjust it up and down. I ended up getting some 7x1 (7 big strands) cable that works really well, you have to have the bushings in there or it will wreck any cable you run right away. My biggest problem is keeping the cable tight, seems to stretch a lot.
Posted 5/21/2013 20:23 (#3110195 - in reply to #3109298) Subject: RE: concrete J bunks
central Iowa
I just got done putting 2 1/2 inch schedule 40 pipe. two rows of it. it is fast to put up I think it was 20 foot pieces and then we took and welded the seems. Made brackets to mount to the uprights on the bunks then slid the pipe through that.
