Search Forums | Classifieds (85) | Skins | Language
Old John Deere 8430 problem
Corn Belt
Posted 5/18/2013 14:21 (#3103784)
Subject: Old John Deere 8430 problem
Northwest OH
The old 8430 has worked good all spring, so today after getting the last field worked up I went to park the tractor, I put it in neutral, let up off of the clutch and it made this terrible grinding noise, it does it ever time I let up off of the clutch pedal even a little bit, what happened? I imagine its not cheap whatever it is. And I know, 8430s aren't ag talk approved, please bare with me.
MF7499
Posted 5/18/2013 15:42 (#3103855 - in reply to #3103784)
Subject: Re: Old John Deere 8430 problem
SW WI
Oh my god, your not running new tractors?!?!? How dare you!!! Sorry wish I could help. If it does it forward and reverse in all gears, I'd bet the clutch, perhaps a bearing on the input shaft but have ZERO experience.
1820-10
Posted 5/18/2013 18:43 (#3104020 - in reply to #3103784)
Subject: RE: Old John Deere 8430 problem
se montana
Splined shaft that goes through the clutch? Don't remember the grinding, ours just stopped moving
ccjersey
Posted 5/18/2013 18:58 (#3104041 - in reply to #3103784)
Faunsdale, AL
I think the tractor is till in gear and moving forward so the park pawl is chattering.
If it's not moving when you let out the clutch, then I don't know. Drain transmission check screen looking for debris/metal?
ChrisTN
Posted 5/18/2013 21:00 (#3104264 - in reply to #3103784)
Ethridge, TN
Can you put it in gear, and will it move??
thor
Posted 5/18/2013 22:18 (#3104491 - in reply to #3103784)
northern MN
Not sure but if it were a dry clutch Id say the throw out bearing. 8430 with clutch problems means splitting it, 30 hours would be my estimate
. May as well put in a clutch while your there, $5000.00 would be my guess in town.
Orin
Posted 5/18/2013 22:28 (#3104514 - in reply to #3104491)
Nusbaum Farms LLC Bellfountain, OR
Can you tell whether the noise is coming from the front half or the back half? I'm thinking that if you cant, the easiest way to isolate it would be to remove the front driveline and then start the engine and see if the noise is there. If so.....it is in the front half. If not......it's in the rear.
-Orin
Corn Belt
Posted 5/19/2013 00:43 (#3104662 - in reply to #3103784)
Northwest OH
Thanks everyone for the reply's! when this originally happened it was in neutral and not moving. It goes in gear easily, but it just grinds so terribly bad when letting up off of the clutch, and as far as I can tell its in the front half.
ChrisTN
Posted 5/19/2013 08:01 (#3104904 - in reply to #3104662)
Ethridge, TN
Tractor has a wet clutch in it, and I've never experienced a failure of one of those.
Next part behind the clutch is where I've seen failures, in the carrier for the 2-speed planetary. You can pull the 2 speed out, without splitting the tractor. Put it in a hard right turn, remove the top shaft, and then pull the large round housing, where that shaft comes out.
Since it will easily go in gear, the 2 speed is where I'd start. No, it's exactly a cheap fix. If you have decent mechanical skills, and an IT/Tech Manual, you can save yourself a big labor bill and do it yourself.
mr8850
Posted 5/19/2013 10:12 (#3105120 - in reply to #3103784)
Minot ND
I would guess its the splines on the input shaft.
