Search Forums | Classifieds (15) | Skins | Language
4450 engine oil pressure sender - only 1 wire?
ncwi4450
Posted 5/15/2013 16:19 (#3099224)
Subject: 4450 engine oil pressure sender - only 1 wire?
Rudolph, WI
Replacing engine oil pressure sender on 4450. Old sensor has 3 wires RE12175 and new one has only 1 connection RE15583. How do I wire this up?
JDTECH
Posted 5/15/2013 16:38 (#3099230 - in reply to #3099224)
Subject: Re: 4450 engine oil pressure sender - only 1 wire?
NEMO
You got the wrong sender. The new sender you have is for a tractor with out the Investigator warning system. Your old RE12175 sender superceedes to a RE208261 and R53014. You will also need either a RE151505 or a RE60578 depending on your tractor serial number and which Investigator warning system you have. Good luck.
School Of Hard Knock
Posted 5/15/2013 17:46 (#3099276 - in reply to #3099230)
Central ND
JD tec is correct. There may even be 3 different senders if I remember correctly.......And try not to ruin the wires as they are as thin as hair on some of those connectors.
