Search Forums | Classifieds (99) | Skins | Language
How to change water pump belt on N-14 cummins
3020
Posted 5/12/2013 10:27 (#3094176)
Subject: How to change water pump belt on N-14 cummins
Northeast Ohio
What's the quickest or best way?
HobbyTRUCKER
Posted 5/12/2013 10:31 (#3094185 - in reply to #3094176)
Subject: Re: How to change water pump belt on N-14 cummins
@FarmerGC79 WCIL
Isn't the water pump ran off the serpentine belt? Just get a half inch drive breaker bar and pull on idler pully, should be big enough to slide over fan.
3020
Posted 5/12/2013 11:10 (#3094232 - in reply to #3094176)
Northeast Ohio
I'm not a mechanic but, I don't think so. Maybe some models are different, this is in a 2000 freightliner, red top. Working on it right now, PITA.
emtbd1979
Posted 5/12/2013 11:26 (#3094252 - in reply to #3094232)
west central illinois
You have to take the fan belts off and then loosen the tightner pulley on the water pump belt. I believe it will slip over the fan but can't remember for sure. If not you will have to unbolt the fan also. Both the water pump and fan drive off the accessory drive.
Edited by emtbd1979 5/12/2013 11:36
(image.jpg)
Attachments image.jpg (69KB - 184 downloads)
Wheatguy
Posted 5/12/2013 14:15 (#3094453 - in reply to #3094252)
Sumner County Kansas "The Wheat Capital"
I think the water pump belt will go over the fan, it is the fan belts themselves that you have to take the fan loose because they are to short to thread over the fan. Don't you just love engineers. I let the fan slip from my grasp once and caused myself a radiator removal and repair.
Andrew_D
Posted 5/12/2013 16:03 (#3094574 - in reply to #3094176)
Newdale, Manitoba, Canada
Also have to take off the A/C belt don't you? I'm not under the hood right now, but I think the fan belts come off, then A/C, then serpentine belt...
Andrew
jonfrahm
Posted 5/12/2013 18:09 (#3094723 - in reply to #3094574)
Audubon,Iowa
while your there replace all belts and start fresh better safe than sorry
