 Eastern VA. No such thing as too many Magnums. | It is the precursor to the 2500. It is fine. Two toolbars were closer together on a 500 than on a 2500, so occasionally the coulter disk would contact the pivot bracket on the shank. (If it has spring reset type shanks) and the coulters can only be 20", instead of 22" like the newer model. Otherwise there isn't much difference. I would pull 5 shanks with that size tractor around here. |
