 central - east central Minnesota - | Indianajones - 3/25/2013 09:15 Building a shop with perma-columns and slab. Looking for info on how others insulated the slab. This will have radiant heat not in floor heat. INDY
Build your slab base, level and compact. The base elevation should be taken inconsideration, with the thickness of the foam, if height is super critical for clearance. Lay plastic vapor barier down and lay foam on top. Tape seams. For outside insulation frost barrier, dig down 2ft vertical (for here in MN frost depths) and out 4ft downward slope horizontal. Fasten foam to outside poles/columns to grade. then lay 4ft sheet down and back fill. This keeps the frost from getting under your slab. I would also lay plastic over the top of the foam, on the outside.
Edited by iseedit 3/25/2013 15:58
(insulaton a.jpg)
(Copy of PA160098.JPG)
(PA190122.JPG)
(PA240139.JPG)
Attachments ----------------
insulaton a.jpg (22KB - 858 downloads)
Copy of PA160098.JPG (66KB - 688 downloads)
