| You know, I laugh when I see all this BS on how bad deere oil is.................Had a 329 Deere irrigation engine with Deere Plus-50 in it, engine was a used combine engine that had zip done to it when we put it on the pump, bottom end looked good, but we wanted to make sure the rig would work before we went into it further. Had that sitting at the river pumping, left, someone drove down there later and called and say the engine wasn't running...............Went down to find the destruction. Water pump belt broke, local guys that put the murphy on it didn't wire it right, so it didn't work, engine kept running, got hot enough it blew the lower coolant hose off, drained it.............Kept running, block got so hot it burned off the paint down to about the crankshaft line and melted high temp RTV I used on a acouple things..........Must have been making some pressure in the case as it blew the dip stick into the river. Something shut it down, which I don't know for sure, but I guess the fuel boiled killing it...............Anyhow it was ROASTING when we got there, but was really supprised their wasn't a hole in the block............So, while bitting nails, I said just leave it cool naturally, we will come back later and see what the story is. 4 hrs later came back, found the dipstick sticking in the river sand, tried to crank it, supprisingly it cranked, didn't hear any noises. So we put the hose on, new belt, and filled it with water, wouldn't you know that old pig fired right up............No noise, knock, anything......Ran like a swiss watch! Brought it back to the shop, fixed the murphy, changed filter/oil, and filled it with anti-freeze..............Put 1000 hrs+ on it since then and have had zero trouble. I wasn't sold completely on Plus 50 at the time, but that made a believer out of me. So if that oil is the cheapest, dirtiest, junkiest oil out there, I am sold on it here!!!!!! Had it been anything else, I'd wager it would have broke down in that heat and would have remodeled the block with a nice skylight! | |
