| Yes, the 6415 is a stripped down 6420, not an "in-between" model. The chassis, hitch, three point, and axles are the same. Our 6415 has a more basic cab then the 6410 (although the same size). On ours the principle difference is in the transmission and hydraulics. 6410/6420 have 24 speed quad with reverser, 6415 has 12 speed synchro w/ reverser. 6410/6420 have the deluxe scvs with the control for hydraulic motors whereas the 6415 has a real budget connector without a flow control. I believe the 6415 also has much less hydraulic capacity. Some of this could be more differences in the options selected at purchase, rather then model, but it is how a ours are equipped. | |
