western iowa,by Denison | 8ft tall walls-12inchs thick,rerod-uprights every 12inchs,horizontal at 12inchs,4000# strength,5ft footings,24 inchs wide,8-10 inch floor-rerod 2x2 squares, Wood-2x6 lumber number 1 or better-2x12-douglas fir-24Ft,drop in anchors lagged down with 3/4 grade 5 bolts-in the bracket that is also attached to every other 2x6 upright,3/4 plywood nailed every 8inchs,2x2-3/8 angle iron braces,all braces and joints on the roof bolted with 5/8 bolts and 1/2x2" flat washers-and wood knee bracing going in tomorrow-screwed with tourqscrews and nailed-(2x6 and bottom and top plates nailed with ring shank 40d)also-raingutter on back to direct water out of back cattle alley way- 66ft longx24ft deep -16ft clearance back wall -22ft tall front with 5ft drop tin to help keep some water out | |
