Search Forums | Classifieds (92) | Skins | Language
Gallons of water corn needs per acre??
farmpro11
Posted 11/15/2007 16:21 (#238780)
Subject: Gallons of water corn needs per acre??
Had a guy tell me today that each corn plant needs about 3 gallons of water per day from shoulder high to after silk. Is this right and does anyone have actual numbers on how much each acre of corn, and how many gallons are used per year for 160 bushel corn?
conservation cop
Posted 11/15/2007 16:24 (#238781 - in reply to #238780)
Subject: RE: Gallons of water corn needs per acre??
Gettysburg, PA
It has been a while so I can't remember where I got the info, but, I remember finding a figure saying a corn plant uses 54 gallons total during the entire growing season??  Wish I could verify that for you.
JimmyP
Posted 11/15/2007 18:34 (#238845 - in reply to #238781)
Subject: Re: Gallons of water corn needs per acre??
Lancaster, OH
Modern Corn Production, circa 1978, says that it takes 5,000 gallons/bushel of grain. At about 100 bushels for the time, that would be about 500,000 gallons/acre or about 18" of rain. That is pretty much in the range of normal rainfall. At 30k plants, that would be 16-17 gallons/plant.
We had very big yields around here and had very little rainfall. I can't imagine that our residual moisture was that good but this is as good as I can guess with numbers. Sorry.
farmers_edge
Posted 11/17/2007 11:46 (#239875 - in reply to #238781)
Belleville, Ontario
My thoughts are 1" of water for every 7 bu. There is a wide variation on this, due to tillage practices (points for no-till!), variety and nutrition of the plant. the more the roots explore the soil, the better, so I'm trying to learn as much as I can about growing roots. Also, K is important for closing stomata openings, so higher available K to the plant will help increase the bu/unit of water.
The Farmer's Edge Agri-coaching
Carl In Georgia
Posted 11/15/2007 18:32 (#238842 - in reply to #238780)
Ashburn, GA, (very close to Heaven!)
Well, I've run some numbers:
3 gallons of water per day per plant EQUALS, assuming a plant population of 30K, 90,000 gallons of water per acre per day. 90,000 gallons of water per acre per day is the equivalent rainfall of 3.3 inches per day. That plant may use that much water, but I don't think so, as there is no irrigation system PLUS rainfall pattern PLUS soil moisture reserve capacity that high imaginable.
I like to think we can make a pretty good corn crop on about 23" to 27" of well timed rainfall plus irrigation events on our sandy soils, from planting to crop maturity, assuming adequate soil moisture at planting. For good measure, let's say we use 25", which equals 678,850 gallons per acre per season (one inch of rain on one acre equals 27,154 gallons of water). Breaking down further, at the 30K plant population, this equals 22.6 gallons per plant over the whole season.
I imagine for 160 bushels, you would not need that many plants nor that much water, but your sols may hold enough moisture that you can have it "built up" prior to the beginning of the peak water demand time of the crop.
JohnDeereGreenWKY
Posted 11/15/2007 20:48 (#238920 - in reply to #238780)
West Ky
I don't know about all those figures. We had some fields this year that got well over 100 bu/ac and we only received 5.9 inches from Jan1-Sep 9 and at that time we had already shelled most of the corn. We also had many days of 103-107 degree temps. I'd say those figures are hogwash myself. Unless the corn roots went all the way down 150 ft underground to hit some well water. We also had a drier than normal fall of last year.
agentj
Posted 11/15/2007 21:33 (#238975 - in reply to #238780)
Central Arkansas
My cheat sheet says that water needs will vary from 20-30 inches depending on weather conditions, plant density, fertility, soil type and days to maturity. In most seasons, the amount of water needed will be about 20 to 24 inches. I don't know how to convert inches to gallons though........
Jen
Rich
Posted 11/15/2007 21:35 (#238976 - in reply to #238975)
Kansas
Use this Jen
http://www.metric-conversions.org/volume/cubic-inches-to-gallons.ht...
agentj
Posted 11/15/2007 21:37 (#238980 - in reply to #238976)
Central Arkansas
Thank you Rich!!!!!!!!!!!!!!!
