Search Forums | Classifieds (27) | Skins | Language
JD 714 chisel plows (questions)
IaAngus
Posted 9/13/2012 12:39 (#2589182)
Subject: JD 714 chisel plows (questions)
Eastern Iowa
I'm looking for a chisel plow, saw a 714 advertised, may go look at it. What were the different options offered on these in late 80s or early 90s? This one has the disc vs straight blades. What were shank options? I need something with good stalk residue flow and spring shanks. I like to pull it pretty deep for corn on corn primary fall tillage.
JohnW
Posted 9/13/2012 13:11 (#2589239 - in reply to #2589182)
Subject: RE: JD 714 chisel plows (questions)
NW Washington
John Deere still has info about the 714 Mulch Tiller on the web. http://www.deere.com/wps/dcom/en_US/products/equipment/tillage_equi...
IH_always
Posted 9/13/2012 21:37 (#2589904 - in reply to #2589182)
I had a 13 shank w/straight blades on the front. It would shallow itself up when in heavy black dirt. Lighter ground it worked OK. Sold it and bought a Sunflower and it stays the depth you set it.
greenpower
Posted 9/13/2012 21:40 (#2589912 - in reply to #2589904)
N/E Iowa
IH always.... what model Sunflower? Do you like the job it does? Any Leveler?
IH_always
Posted 9/13/2012 21:57 (#2589965 - in reply to #2589912)
It is a model 4511 disc chisel disc. No harrow. 15 shank. Rear disk gang folds up, front gangs do not fold. Makes a 18'9" wide cut. Pull with a JD 9420. It knows it's back there. In corn stalks it leaves the ground a little cloddy with root balls in the fall, by spring it's not so bad as a lot of the stalks and root balls decay.
greenpower
Posted 9/13/2012 21:38 (#2589908 - in reply to #2589182)
N/E Iowa
We had a 1991 years back, had it for 9 years. It had walking tandems, hydraulic disk gangs, 4 inch twisted shovels, spring auto reset shanks. s tine levelers..... I don't much care for. Good machine for the job it's used for. I believe 10 inches might be max depth. I pull our 07' 714 11 shank with a 240 hp 8300, and its got its hands full when it's buried.
Tommy
Posted 9/13/2012 21:59 (#2589968 - in reply to #2589182)
Iowa
They still make the 714. I am not sure but I think one as old as you ask about would be a 712.
I recently bought a 2007 714. I have been told that the 714 has a solid rear frame, vs 4x4tube on the 712. Supposed to help keep it in the ground and be stronger for hanging a harrow on the back. Salesman also told me the disc ones were not hyd. adjust on the discs, I know the coulter one I bought has hydraulic -adjustable coulter depth. Salesman also told me not to get walking tandems on the smaller models as the shank configuration is different and the extra tires tend to accentuate plugging in fluffy residue. Otherwise, after asking around, people tell me they don't plug like older models. I know there are three full rows of shanks vs 2 or 2 "stretched" on the 1980's-'90's chisels. One guy I talked to said he had plugged his in untouched standing stalks (200 bu corn) when damp, but otherwise it never plugged. The shank trip force is quoted as 2x that of the old Glenco soil savers according to JD salesman's comparison specs they can access on their Internet sales info.
I don't know if they all do, but the one I bought has the single-point depth control like on a JD field cult.
I tried a JD 512 ripper on 600 a last fall, and hated it. Guy running my field cult. this spring asked why some fields were ridged-- answer: wherever we ran the 512. I quit disking in the fall 20 years ago and the 512 was just a glorified disc in my opinion, and ridged like a disc of 20 yrs ago as well.
steveMIfarmer
Posted 9/13/2012 22:37 (#2590081 - in reply to #2589182)
Subject: Re: JD 714 chisel plows (questions)
West Michigan
We had one. Top five worst pieces of equipment we have ever owned. I would look at krause, sunflower, land-all ect. Ours was early 90's 17 shank.
