| I had a 2007 Bobcat S300. Now have a 2008 NH TC80 compact wheel loader. The TC80 is the same machine as a Case 321 and same size as the 908 Cat and 304JD. The compact wheel loader does almost everything better, except in tight areas. The TC80 lifts more, better visibility, better traction, faster road speed, safer to travel up steep hills, tears up the ground less, can get in and out easier and with load lifted ect.
Skid steer better at seeing bucket edge.
Most of the newer compact wheel loaders use a skid steer attachment plate. I use all the prior equipment I had for the skid steer-post hole digger, tree spade, snow blade, snow pusher, broom, grapple ect. I bought a skid steer to Euro loader adapter for the front. I can also use my tractor loader buckets on it if I need to.
I bought my used NH in 2010 with 200 hours. Found it on the internet at a Ford car dealership in New Hampshire. Saw pictures a bought it. Had it shipped 2300 miles to Nebraska. Paid $42,000 for it and thought that was a bargain. Sold the skid steer 2 weeks later for $27,000. Really liked the S300 but love the wheel loader more. I have a Case/IH Maxxum 125 with FEL. The wheel loader is much more nimble, better visibiltiy and easier to use than the tractor. Tractor will win only in muddy conditions. My TC80 pushes well. I can spin all 4 tires and hard dry ground. On some machines, it is an option to have limited slip front differential. I have that on mine. Converts it from 3 wheel drive to true 4 wheel drive.
I have a dump truck with tall sides. It is just under 11'. The TC80 can clear the side but I cannot dump the normal bucket. My pins for the bucket are at 11' 3". However, I have a 4in1 bucket, and can open the grapple portion and allow the load to fall out and don't need to tip the bucket.
Edited by radman1 9/6/2012 01:33
