Search Forums | Classifieds (74) | Skins | Language
What fluid for Ford TW15 steering?
AaronB
Posted 8/19/2012 15:12 (#2547532)
Subject: What fluid for Ford TW15 steering?
Hey folks, just put a new steering motor on a good ole Ford TW15 tractor and want to make sure we are getting it right. Dont have access to CNH fluids. Is Hygard ok to use or should we be using an auto style power steering fluid? Thanks!!!
RodInNS
Posted 8/19/2012 16:22 (#2547645 - in reply to #2547532)
Subject: RE: What fluid for Ford TW15 steering?
134D is the specified oil. HyGuard is fully equivelant. In the distant past Ford has specified automotive PS fluid in some models. I've used 10W30 engine oil more often than PS fluid tho. In reality... just about anything wet and slippery will work in those PS systems.
Rod
Reyem
Posted 8/19/2012 16:38 (#2547665 - in reply to #2547532)
Subject: Re: What fluid for Ford TW15 steering?
SW IA
I've used ATF for years in Ford power steering units and never had a problem.
tx68
Posted 8/19/2012 19:40 (#2547857 - in reply to #2547532)
Ontario
Used atf in our tw 35 for 30 years
mitcornecks
Posted 8/19/2012 22:52 (#2548322 - in reply to #2547532)
East Central Kansas
We always use the same 15-40 that we use in the engine. So when the seals go out, all the oil ends up in the crank case and we don't have to worry about engine oil contamination.
super90
Posted 8/20/2012 01:56 (#2548599 - in reply to #2547532)
53916
Same universal trans/hydraulic that gets poured in the rear end.
