Nwmo | I would recommend you stay away from the JD carts made by UFT. We have 2 of them and they are junk. The shear bolts go out a lot if you don't baby it when you start them up. You have to have a swing away auger to clean them out so you can put a new bolt in it.
The older style carts had weak axles, They had bolt on extensions for some reason. We have broken both sides of ours. We would be screwed if we didn't have a grain vac, or if we had done it away from home.
UFT didn't know how to make the augers seat properly when unfolded in the unloading position so a significant amount of corn/grain will leak out if you don't put foam tape in the crack between them or clamp it down with vise grips.
Slow unloading, side auger instead of corner auger, weak axles. JD doesn't really offer many parts for them, usually they tell us its a obsolete part and they can't get it. I really would hate to see you buy one because you will most likely be unhappy with it. Ez trail I think, makes pretty much the same cart and you can buy new ones for $10,000.
Hope this helps,
Devin | |
