Crawford County, Robinson, Illinois | Cliff SEIA - 6/30/2012 14:41 . Personally I would skip the belt meters and put that money into a good population monitor
I mounted my 5400 with 900 units directly on the three point, did some no till, but not a whole lot. I used the population monitor from my 900 corn planter after adding sensors to the row units just like on the planter. I loved that unit, only trouble I had was a sway block broke on my 7140, the wheel on the drill ruined an outside duel. Be sure you have a lot of weight on the front if you don't use a cart, when the box is full, I had to brake the tractor around at the end, as the front was so light it wouldn't turn it. Worked great except for hills, afraid to turn on the ends, if hill was steep, I backed around at the end so as not to lose control. Loved the job it did on beans, I did no till a lot of pasture ground, hence the hills I mentioned. Could put beans in fescue stubble and get them covered, even when dry. I never broke any row units on mine. |
