![](/profile/get-photo.asp?memberid=1306&type=profile&rnd=709) central - east central Minnesota - | You'll have issue's with rock with either . . . . you need to hold a bucket or pusher up, off the ground, the first snows - or rocks will billow up with the snow, untill you get a snowpack base. In all reality, for first snows, a roller would work best for creating a base for pushing or blowing snow on . I think, in your location, if you have wet snows, or hard wind packed snows - a 10ft pusher for a 200 bobcat would be too much. As someone eluded to, a snow pusher doesn't give additional traction from weight of snow - a bucket can give some traction from weight of snow. A snow pusher is much faster though, as you do not need to dump .. . so it makes some difference at the end of the day, when cleaning large areas. It's very easy for a skidsteer to "push" the snowpusher down in the rock/dirt and push it out. The loaders are not like a tractor loader that has a better ability to "float" over the ground, when the loader is placed in float. The quick - tach skidsteer snow pushers are uptight and close to the skidsteer . . . it makes it harder, then a bucket, to pile snow. With a bucket, you can kind of "toss" the snow up-top the hugh pile. With a pusher, it seems to fall back into the skidsteer. On a pusher, it'd be nice to have the blade out away from the skid about 2ft, to help with piling . . . THis is what I had and then cut down and mounted a skidsteer plate on it. I liked it as a 3pt better for float and piling snow . . . . (pic)
(P2120099.JPG)
(P2190016.JPG)
(P3030037.JPG)
(P2190018.JPG)
(PC240222.JPG)
(PC070066.JPG)
(PC200078.JPG)
Attachments ----------------
