Search Forums | Classifieds (82) | Skins | Language
CaseIH MXU 110 - code 14900 ?
BBfarms
Posted 8/27/2011 16:54 (#1933068)
Subject: CaseIH MXU 110 - code 14900 ?
SE Michigan
2004 MXU at "cold start" about 4/10 times I get 14900 code with the caution light. Also tractor seem to idle very low them it comes up to "normal" then the light goes out.
Looked in the book I have (MX 110 pro) and all I could fine was "starts with....14 - instrument cluster..... could not find the 900.
Any thoughts........
scott nelsen
Posted 8/27/2011 17:39 (#1933130 - in reply to #1933068)
Subject: Re: CaseIH MXU 110 - code 14900 ?
Leeds, North Dakota
When I can get into dealer portal will post back, system is down, Scott.
outsidethebox
Posted 8/27/2011 20:13 (#1933297 - in reply to #1933068)
Subject: RE: CaseIH MXU 110 - code 14900 ?
Memphis, NY
I had that code on a NH TS one time(I think). If I'm remembering correctly, it was for fuel system water separator(or sensor).
Followme
Posted 8/27/2011 22:29 (#1933540 - in reply to #1933068)
Litchfield, NY
14900= Central Controller not connected. Check connectors on back of ADIC and connectors on central controller located under rear inside cab trim, attached to inside rear of cab.
