Search Forums | Classifieds (267) | Skins | Language
combine chain oilers
micronj
Posted 7/16/2011 16:41 (#1865958)
Subject: combine chain oilers
Considering adding an automatic chain oiler to the 2366 combine. Other than CIH, where can you buy such a system? Do they work well and are they worth the money?
Thanks.
boog
Posted 7/16/2011 17:31 (#1866026 - in reply to #1865958)
Subject: Re: combine chain oilers
We had a Lincoln automatic oiler, IIRC< on our 2388 that we purchased thru our CIH dealer. When you swing the unloader out it would give the chains a shot of oil. Takes awhile to get the flow adjusted where you want it & if you're like us where we fold the auger back every time things can get kind of messy. We bought extra lines & oilers & had our 1083 cornhead settp for it as well. Just had to remember to uncouple the lines when you were changing heads. Worth the money IMO.
Edited by boog 7/16/2011 17:32
Buster 50
Posted 7/16/2011 17:52 (#1866044 - in reply to #1866026)
North West IA/western AZ
What do they cost?
boog
Posted 7/16/2011 18:58 (#1866125 - in reply to #1866044)
4-5 yrs ago they were $300 plus. That didn't include the extra couplings, lines & oilers.
WD45 Fred
Posted 7/17/2011 10:01 (#1866320 - in reply to #1866044)
Stayner, Ontario, Simcoe County
We added a chain oiler to the 2388 and now have a chain oiler on the 8120. Good option to add.
T800
Posted 7/16/2011 18:25 (#1866092 - in reply to #1865958)
Lee Co
what oil do you use in it?
7720gas
Posted 7/16/2011 18:36 (#1866110 - in reply to #1866092)
I have one on my agco rd baler, each chain gets a brush and oil line, every time you dump a bale it oils the chains, you can adjust the oil flow rate, and i use motor oil 15-40.
this set up is not a lincoln, but I think it starts with an S, I think.
one thing about it, the sides of the baler are not going to rust out..
boog
Posted 7/16/2011 19:00 (#1866127 - in reply to #1866092)
15w-40 or Hy-tran. On a combine you'll want something that will flow when it's cold out. Lines are small & by the time you get around to the elevator drive chains can be fairly long.
Edited by boog 7/16/2011 19:01
mulberrygrovefamfarm
Posted 7/17/2011 09:36 (#1866272 - in reply to #1865958)
Subject: RE: combine chain oilers LubeMinder
Iowa
LubeMinder by Suburban Mfr for your 2300 series combine I think.  You can order through your dealer or LubeMinder, but the LubeMinder customer service is excellent.  I can't recommend them highly enough.  They work great and they are well worth it.  Can you tell I like mine?
