 Northwest OH | <p>It is a proven fact that the tranny in a 88 series is the direct desendant of the MAGNUM tranny. That is not rumor, that is not what someone told me, it is proven fact. The 88 series is identical to magnum except with synchronizers instead of powershift cluthces. With a 88 series you are getting a "almost Magnum". Everything the same except the cab and engine. Nice cab, similar layout the a Magnum (the cab is the same in dimension), great hydraulics. The DT 466 in a 88 series is a GREAT engine, with a proven record in the field and on the road. And if you get FWA with the 88 series it just engages with a switch, not a lever like the case, the FWA on the 88 series is the same on a early Magnum except for a few small changes. The 504 is a good engine but I would not buy a tractor on the engine alone. In closing, I would go with the 5288, durable rearend, good stout tranny, Heck of a engine, and nice cab, and better resale also than the case. Hearsay seems to supersede experience on this forum at times.</p>
Edited by Corn Belt 6/25/2011 23:02
