When you're talking about a 30 yr old combine with over 2000 hrs on it hrs matter way less than condition. A 1460 with 4000 hrs may have had almost everything replaced in the last 500-1000 hrs and be in better shape than a 1460 with 3000 hrs that has had very little done to it as far as replacing major items. FWIW our 1640 has ~3300 hrs on it and I'm not at all scared to run it for a while yet. It has had some work done to it and will need more done to it but it is easy to work on if you have any mechanical skills at all. It will likely be here until we need a bigger combine. |
