Search Forums | Classifieds (1) | Skins | Language
60 and 70 series John Deere 4WD
zach_deerefan
Posted 5/8/2011 18:36 (#1766137)
Subject: 60 and 70 series John Deere 4WD
WCIA
Possibly looking for a 8560-8770 JD 4wd and would just like to know the good and bad about these tractors. will go with the 24 sp tranny and would like to find one with a PTO. Is the 70 series improve a lot over the 60? Also what engines were in this. Thanks. Have a safe spring!!
SDFarmboy
Posted 5/8/2011 19:07 (#1766184 - in reply to #1766137)
Subject: Re: 60 and 70 series John Deere 4WD
The 8560 and 8570 share the smaller block 7.6 L engine, and are good for maybe 250 HP. The 8760 and 8770 go with the bigger block 10.1 L engine and HP is upped
to 300 HP +. The 70 series offer Electronic engine control and it offers an increase of extra power when lugging, and I feel they are better on fuel also.
I had a 8770 and really liked that tractor, not one problem in over 4,000 hrs. If you can use the horses, get the bigger model. For tractors this age it comes down
to hrs. and condition.
#1pilsner
Posted 5/8/2011 19:11 (#1766191 - in reply to #1766137)
Se. Sk.
60-70 series were excelent machines. they were built heavier than the 9000 series. 60s had mechanical engines and 70s had electronic engines with field cruise. finding one with a pto will not be easy
Eric9870
Posted 5/8/2011 20:58 (#1766384 - in reply to #1766191)
Upstate New York
What was heavier built on a 70 series than on a 9030?
JD fanatic
Posted 5/9/2011 09:02 (#1767129 - in reply to #1766191)
mw
I will disagree with that, I dont know what's heavier on a 60 or 70 than a 9000, just got out of owning an 8760 by trading to a 9300 and let me tell you, there is nothing light weight or flimsy about a 9300 so i'm not sure what your comparing to.
8760 is a really nice machine and about as solid and reliable as 4wd's get. But i'm not sure you would like the power of an 8560 (having owned both) the 8560 seems to have trouble carrying itself alone up a hill in road gear, just too much tractor for a 7.6L engine imo, not sure what your plans are for it but those were my thoughts. Ended up trading up from the 8560 to an 8760 after one season and that was just pulling a 26ft 637 and a 27ft 726 finisher.
Farmin' Fireman
Posted 5/8/2011 20:27 (#1766327 - in reply to #1766137)
C KS
We had a late 8560 with electronic engine. It didn't have field cruise or decelerator but had no mechanical linkage from the throttle to the pump.
Fullthrottlefarmer
Posted 5/9/2011 09:06 (#1767134 - in reply to #1766327)
North Dakota
Get a 70 series they had the bugs worked out by then. The injection pump on the 8960 was junk.I think John Deere put there own pump on the cummins and it was not good. They turned it back over to cummins on the 70.
Fla Veggie Farmer
Posted 5/8/2011 21:25 (#1766452 - in reply to #1766137)
Subject: 2 questions
Southeast Florida
Why must you have a 24 speed? I've seen more failures with the manual transmission than p/s
Why do you want 85-87 sizes? The 89's are basically the same tractor with one big differance; a NTC-855 Cummins is under the hood and there's a few 89's on tractor house with PTO listed.
Edited by Fla Veggie Farmer 5/8/2011 21:26
bigwortham
Posted 5/8/2011 22:26 (#1766628 - in reply to #1766452)
That'll be 400hp that you'll be able to work with too. From my personal experience, that tractor can pull a 36' Landoll disc with a double rolling basket harrow all day long. It doesn't have a pto, but like Fla Veggie mentioned, you can find them with pto's on Tractorhouse.
#1pilsner
Posted 5/9/2011 11:41 (#1767264 - in reply to #1766137)
Se. Sk.
dont have manual in front of me but i know the shipping weight on a 9100 is less than a 8570....hinge area is lighter......as with any 4wd make sure higes get lots of grease!
