NW Ohio,near Findlay | Agree, however if one is computerized, make sure you don't lose ground. If you try and start with jumpers on, and the draw of starter might make you drop connection. With the computer system, they are grounded to frame, and they will be the ground and burn the system up. Drove a perfectly good Dodge Van to lake, run the battery down, jumped it. Trying to start it, cables lost contact, shook them, started van. Transmission from that point on was screwed up, wouldn't shift correct, shifted it manually somewhat to get home. New computer box, and yes I had the jumpers on correctly, I did it. OK to charge with another battery on jumper, but unhook cables when attempting to start, so my $1000 tranny man said. I know my new van, I'm not jumping anything, absolute emergency, would unhook battery. What to others think. | |
