| An ATU will work just perfect in your tractor. I have setup and used several of them. Of course the ATU isnt as accurate as an integrated valve, but they do a nice job, are cheaper, and give you flexibility. A valve for a tractor would be around 5 or 6 thousand. The ATU is 2 thousand and can pretty much be moved to anything.
Here are a few options and prices
Alot of the cost depends on what signal accuracy you want, which depends on what you want to do with your system. SF1 is guranteed within 10 inches, however it runs alot closer than that, for $5500 more SF2 is guaranteed with 4 inches and prolly runs closer to 2 inches. If youre looking for repeatibility, then you could go RTK, which is sub inch, for an extra $4300 on top of that. Also, the 1800 display is for autotrac only, meaning if you are wanting to yield map or document anything, a larger more expensive screen is needed, the 2630. Let me know your equipment and what you would like to do with your system throughout the year. My cell is 815-252-3927
This is honestly about the cheapest way to go for just autotracking. I would call this the universal tillage system. Its fairly cheap but very easy.
1800 Display $1695
SF1 Activation $3000
SF1 Starfire 3,000 $2695
ATU 200 $1995
Brackets and Harnesses $700
Here is a more expensive system, but will allow for documentation or yield mapping.
2630 $5895
SF2 Activation $6500
SF2 Starfire 3,000 $4695
ATU 200 $1995
Greenstar Harness and Brackets for 8000 $1100
